I’m using the basic log rotate, for Docker, linux:
--log-driver json-file \
--log-opt max-size=10m \
--log-opt max-file=5 \
--name storagenode storjlabs/storagenode:latest \
I get that it creates 5 files of 10MiB each. When I use the command:
docker logs storagenode
or
docker logs storagenode -f 2>&1
I get the last file, I think, because it prints only a part of the logs. I don’t get the startup entries. It’s on info level, and node runs from 130h. I use the custom level to ingnore the pieces in and outs. I don’t believe it already reached 50MiB.
How can I check all 5 files and how can I check the size of each file, just to be sure it uses those settings?
Or it’s just a dislay limitation in linux? Maybe it shows only the last x lines?
