Title says it all. I have about 7GB of ‘Trash’ on my node.
It automatically deletes after 7 days like magic
trash in the storagenode folder is potentially still being used and you can be punished or might even get your node DQ for deleting it.
if you don’t know what you are doing then you shouldn’t be messing around in the storagenode data at all.
to be frank, no offence… just happens a lot, that people think they can just change or delete stuff like they want.
