What did you enter for step 8 ? As you said earlier you didn’t enter anything. You need to enter your static IP or use DDNS.
Hello @maj0,
You specified your local IP as an external address, you should use an external IP instead (if it’s static) or DDNS hostname. In both cases it must be with port, i.e.
contact.external-address: my.external.address:28967
or
contact.external-address: 20.40.32.11:28967
Your current public IP you can see there: https://www.yougetsignal.com/tools/open-ports/, it must match the WAN IP on your router, otherwise port forwarding will not work.
In most cases you do not have a static public IP, so tomorrow it could be different and node will stop to work. So, you should register your own DDNS and use it instead of IP in the config.yaml: https://documentation.storj.io/dependencies/port-forwarding
I would recommend to configure your router to update your DDNS hostname (it usually in the DDNS section) instead of using an app on your PC.
