How to get in localhost web site this site cant be reached ERROR CONNECTION REFUSED
i have a problem i cant seee my nodes and web dont open
What is the URL that you are using ? Which browser are you using ? Is it GUI or docker ?
im using GUI …
What does http://127.0.0.1:14002/ show ?
IT SAYS this site can t be reached.
Which browser are you using?
google chrome . .
Show result of this command in powershell
Get-Service storagenode*
You need to start the storagenode service. If the service stops again, then you need to look in to the storagenode.log file.
Use this command in powershell
Start-Service storagenode
when i write in powershell Start-Service storagenode it doesnt do anything.
The powershell must be in administrator mode (elevated mode) then try that command
here u go i run in administrator mode. and nothing happend
Show result of
cat "$env:ProgramFiles\Storj\Storage Node\storagenode.log" -tail 20
What did you enter next to contact.external-address in config.yaml file under C:\Program Files\Storj\Storage Node ?
i didin t enter anything . but it says that external address split host part faild.
Follow the installation guide so you won’t get errors like these.
https://documentation.storj.io/setup/gui-windows/storage-node
ok but i tryed like 10 times thanks for help
