How to get more Token
I can’t create more tokens at the site, it just said “502 bad gateway nginx/1.14.2”
What can I do too create 4 more?
Thanks!!
What kind of tokens and which website are you using ? You can post its URL for us to get a better idea.
Step 2. Get an Authorization Token - Storj Docs
This step is not required any more. Identities can be used without authorizing them manually!
Where can I get it insted?
Okey!
Thanks! :slight_smile:
I will do it without token then.
//Fredrik.
