It depends on how much data you have from each satellite.
But you should start to see a drop in a week or so (I think garbage collection is still held for 7 days even in a Graceful Exit)
Roughly my 2 x 4Tb drives (which were both full) are taking around 1Tb to 1.5Tb a week to G.E.
Started in the 2nd week of February and I’ve still got 300Gb on one drive and 1.14Tb on another left.
i think is someting bad:
storagenode exit-satellite
2025-07-08T03:18:18Z INFO Anonymized tracing enabled {“Process”: “storagenode”}
2025-07-08T03:18:18Z FATAL Failed to load identity. {“Process”: “storagenode”, “error”: “file or directory not found: open /.local/share/storj/identity/storagenode/identity.cert: no such file or directory”, “errorVerbose”: “file or directory not found: open /.local/share/storj/identity/storagenode/identity.cert: no such file or directory\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdGracefulExitInit:110\n\tmain.newGracefulExitInitCmd.func1:44\n\tstorj.io/common/process.cleanup.func1.4:402\n\tstorj.io/common/process.cleanup.func1:420\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:116\n\tmain.main:34\n\truntime.main:283”}
This command is incomplete. You need to provide the path to the identity with the --identity-dir option and to the config with the --config-dir option.
If you run it inside the container, it should be (it’s a literal command, you shouldn’t replace anything in it):
