The reason I’m leaving the network is because I have two of my miners, one of which I’m going to use for another purpose.
I didn’t know when I was setting up, but when I found out, the two miners’ nodes were different
So I’m going to shut down one node.
There are some known problems that could cause a graceful exit to fail at the moment. I advise waiting until those are fixed. You could of course lower your storage allocation in the mean time, but data won’t be removed until customers actually remove it. So I wouldn’t expect a lot of extra space becoming available any time soon.
HI all, i am also looking to do a graceful exit as want to get out of crypto before end of tax year. I have been running node for 12 months and don’t find it viable and i have to find more time in my life.
I am using the GUI on windows. Where can i find a walk through to exit please?
I may be back some day.
Just a question: What does this mean in bold text bleow
For Windows GUI users, the exit command should look as follows, but be sure to point to your own identity and config directories (in cmd.exe ):
I had to exit one satellite at a time by copy/paste name into cmd and repeating above procedure for each satellite but you can add all leaving space between each satellite. Then click ‘enter’.
On one of my satellites i get the following message:
“You are not allowed to initiate graceful exit on satellite for next amount of months:
Error: You are not allowed to graceful exit on some of provided satellites”
Any reason why??
Is it because its a new satellite which had only recently come on line for the last 3 months?
1, Do i have to leave the ‘cmd’ window open?
2, Should the console still be operational if i have done the exit correctly?
