How to start Docker Gracefull Exit
Hey,
after a long time, i want to shutdown my Nodes now.
But whit the “How to” it didnt work.
I start my Node whit this Command. How i must edit it, to start the Exit?
docker run -d --restart unless-stopped --stop-timeout 300 -p 28969:28967 -p :14004:14002 -e WALLET="xxx" -e EMAIL="email" -e ADDRESS="xxx.ddns.net:28969" -e STORAGE="10.5TB" --log-opt max-size=50m --log-opt max-file=10 --mount type=bind,source=/home/pi/.local/share/storj/identity3/storagenode,destination=/app/identity --mount type=bind,source=/mnt/storagenode3,destination=/app/config --name storagenode3 storjlabs/storagenode:beta
You should not edit it. You need to execute an additional command when your node is up and running and online.
Use the commands from the guide:
I would recommend to opt-in for zkSync or Polygon, if your held amount with undistributed payout is less than 4x transfer fee of ERC20 token (see 19 Gwei | Ethereum Gas Tracker | Etherscan to track it), because the final payout is a subject of minimum payout threshold.
Or at least do not delete the identity after finishing of graceful exit on case if you change your mind.
I’m curious, what is the identity of a node which graceful exitted the network useful for?
To opt-in for zkSync or Polygon. The wallet features enabled per-identity basis.
