When I checked last time there were like 4K payment addresses but look how little SNOs showing up here even after chapter 11. I guess the whales already using multiple IDs.
Like, many people submitting different W-8BENs?
More like multiple accounts so each earns less than $600usd/year: so no W-8BEN required.
Well, maybe they should start requiring them for smaller accounts too.
They did not even pay their own tax obligations. ![]()
Someone at Storj has a thing for $50. KYC if you earn more than $50!
Or did that guy get fired…
How does it make sense? It’s taxpayer identification. Are they allegedly using different taxpayer id? This is … very illegal.
It’s still required. It does not matter if you receive income in one or 5 streams.
The $600 limit is well-known. Just group your nodes together by unique wallet+email… and Storj will never ask you to fill out paperwork for Uncle Sam.
Yeah, allowing this to be possible might be unpleasant for Storj Inc. ![]()
This is not a limit. It’s a threshold, when storj is required to report, (and as a courtesy send you 1099 in US). As a node operator you are required to report all income to your tax authority, regardless of whether storj sent you a paper. So if you earn less than 600 – it’s MORE work, not less.
I don’t think storj cares if your commit tax fraud… but they should — another reason to KYS to avoid dealing with known fraudsters.
@Roxor I think you just pointed out why I’m not convinced by the historical comparison.
each time the node count continued to grow after
But node count is exactly the wrong metric here.
You just agreed that one operator can run more nodes on the same hardware, and that /32 could make that even easier. I can also turn fewer HDDs and fewer connections into roughly the same number of nodes.
So 10,000 nodes after a payout reduction do not tell us whether we still have the same number of operators, HDDs, independent connections, failure domains or spare capacity.
And that also makes “near-zero-risk” difficult for me to reconcile with waiting three months to see what happens. If we need three months because SNOs need time to react, then the risk is precisely in the reaction we cannot see yet.
Your gunshot analogy is actually pretty good — but I think it proves the opposite.
If Storj saves $11k–22k/month while creating long-term damage to SNO trust, redundancy and capacity, that isn’t “necessary bleeding”.
That’s like amputating a leg because you want to lose weight.
Yes, the number on the scale goes down immediately. But you haven’t solved the actual problem — you’ve just damaged the system for a comparatively tiny numerical improvement.
That is the part I still don’t understand in your “near-zero-risk” assessment: at what point does a saving become too small to justify deliberately degrading something that took years to build?
And regarding the /24 change, @elek clarified today that it will be replaced with more sophisticated, partly undisclosed placement rules.
To me, that actually makes the decision even harder to understand.
The /24 rule was simple and worked. I’m probably a pretty good example of that: to scale my operation this far, I still had to distribute it across hundreds of physical hosts and a large number of independent /24 networks. The existing rule forced real infrastructure behind the nodes.
Now Storj is spending engineering time designing, testing and maintaining a more complicated hidden system to replace something that already worked.
If $11k–22k/month really matters that much, why spend engineering money reinventing this at all?
Keep the working rule. Save the development cost.
I even offered my programming help above for work specifically aimed at bringing in new paying customers, and there was no interest.
So it becomes increasingly difficult for me to reconcile “we desperately need every $11k we can save” with these priorities.
The numbers keep pointing to the same thing: SNOs are already cheap. Storj’s problem is revenue, not that SNOs cost too much.
Yes, and the whole “us company sends money to anonymous wallets to foreign nationals monthly for… reasons” business….
ME:
350x nodes
10x data
1x sno
I guess: for a company facing the abyss: it’s if the savings are too small to offset the cost to implement them. I don’t know the costs to lower the payout: but in my mind it’s very low. Probably less effort than we’ve put into discussing it.
A change saving $11k–22k/month is worth making. And yes… “as part of a larger plan” ![]()
How do you judge if a saving is too small? Maybe you don’t think it’s too small: but you’re frustrated we have no visibility to a larger plan that could “move the needle”?
That’s good. I don’t know if it was you or someone else that said it first: but no matter how we feel about it… Elek tweaking node-selection rules will have no affect on if they leave Chapter 11 or not.
Specifically scale is their problem. Unlike in the past when they were paying a firehose-of-tokens (where profitability didn’t even work on paper)… it sounds like today the margin is there. They’ve finally been charging customers more per-TB than they’ve been paying SNOs. They make money on every TB…
…but they aren’t storing enough TB…
…for that margin to be enough to run the company and pay past debts.
I hope the big plan is trying to address that scale. All SNOs can really affect is that per-TB margin. And it will improve starting Sept 1st.
(I also hope it’s a small change… that’s part of many others… that build like snow in an avalanche… ultimately burying Storj in money
@Roxor I think your last post actually brings us much closer to the real point.
You just identified the actual problem yourself:
Exactly. Scale is the problem. SNO cost is not.
So for me the question is not simply whether $11k–22k/month is larger than the implementation cost of changing a spreadsheet field. The question is whether that saving is large enough to justify the consequences and whether it addresses the problem that is actually killing the company.
It doesn’t address scale.
And I’ll go one step further:
If Storj could actually demonstrate that, after everything else in the restructuring plan has been done, the final $11k–22k/month is genuinely the difference between Storj surviving and shutting down, then yes — I would even accept a temporary emergency reduction to $1.35/TB for storage and $1/TB for egress, strictly for the limited period until new customer revenue covers it.
Especially if Storj actually implemented something along the lines of the customer-acquisition plan I proposed above.
But only then.
And only in the extraordinarily unlikely situation that those last few thousand dollars really are what stands between Storj and failure.
Because so far the court numbers show the opposite: a much larger revenue, scale, cash-flow and legacy-liability problem. They do not show that SNO compensation is what puts Storj over the edge.
I’m even deliberately leaving Inveniam’s ~$4.038M prepetition claim out of this argument. The filings list Storj as owing that money to Inveniam, but I still haven’t seen enough documentation to say confidently whether that was a loan, intercompany funding, expenses or something else.
So I’m not using it to strengthen my case.
The real fix is more paying TB. Everything else is just moving pennies around the spreadsheet.
Maybe we’ve always been in broad agreement - we just took a long meandering path to realize it ![]()
It does sound unlikely Storj will be able to restructure and renegotiate with creditors and cut-costs… enough to continue to limp along without a new owner. Someone will have to buy them.
And that someone will have to pour the marketing dollars in to steal Wasabi and Backblaze customers. Or appear much sexier to customers paying big-$$$ to Amazon for real S3. Or become the default whitelabelled-S3-provider that all other small businesses resell-with-their-logo-on-it.
(Alexey should be along in a minute: to suggest if-we’re-so-smart-why-don’t-we-take-over-Storj-marketing
@Roxor Maybe we actually were. ![]()
And that is exactly why I keep coming back to customer acquisition instead of squeezing SNOs.
Whether it is a new owner or Storj itself: someone has to solve the scale problem. Steal customers from Wasabi and Backblaze, make Storj attractive against AWS S3, and especially build something that smaller businesses can easily resell as their own storage product.
That is also why I offered to help program something aimed directly at bringing in paying customers.
Cutting another $11k–22k/month doesn’t even meaningfully buy time at the scale of Storj’s current financial problem.
Getting another few PB of paying customer data actually changes the company.
@GfTmbH could make storj his 5th company. I mean he is the man with the business plan. ![]()
One of the companies rents caravans, that’s not even that much different to storage lol ![]()
A great sales person can sell everything. Unfortunately I am just another software dev.
