How to Survive - without reducing SNO compensation
No. That’s kinda why you put “obvious” in the sentence. There are decisions so heavily biased towards success that a more detailed look feels pointless.
Just drop the payouts and wait three months to see what happens. Chapter 11 is exactly the time to take risks: the alternative is insolvency.
Storj can adjust payment in both directions if needed. For now it is a small saving but it is a low hanging fruit as well. I am ok with storj testing the limits.
@littleskunk I understand that approach, but this is exactly where I see the problem.
SQL will only show you the effects that are visible in the network data — and often only after they have already happened.
If I consolidate 4 HDDs into 1–2, reduce several connections to one after the contracts expire, stop buying hardware, or simply decide that I will never invest again at these rates, your SQL queries may barely notice any of that.
The node count may even stay almost identical while the actual physical redundancy gets worse.
So by the time the obvious metrics finally tell you “we went too far”, a lot of the damage may already be baked in — and some of it may never appear clearly in SQL at all.
That is why I don’t think we can rely only on observed network decline to decide whether the rate was too low. Some of the most important effects are delayed or latent.
So would you be open to reconsidering the rate based not only on SQL, but also on effects we know the SQL data simply cannot capture?
That is… a pretty open question. I guess the answer will always be yes: other data could be convincing? But you don’t say what it is.
Are we missing a side of the equation? :winking_face_with_tongue:
(I’m kidding I’m kidding)
@Roxor @alpharabbit And that is exactly where I disagree with the “just test it and reverse later” idea.
The payout rate is reversible. The reaction to it isn’t necessarily.
Storj can raise $1.35 back to $1.50 with one change. But they can’t instantly undo sold HDDs, cancelled lines, consolidated infrastructure, exited SNOs or lost willingness to invest again.
And I also don’t think “the alternative is insolvency” fits here.
At ~$11k–22k/month, this does not decide whether Storj survives Chapter 11. It only improves monthly cash flow by a very small amount compared with the size of the actual problem.
So this isn’t really “take the risk or go insolvent”.
It is take a delayed, partly irreversible risk for a relatively tiny cash-flow improvement.
@Roxor Exactly. :smiley:
That is the missing side of the equation.
SQL can show exits, capacity and utilization. It cannot directly show infrastructure that was consolidated, hardware that was never bought, contracts that were cancelled for next year, or an SNO who silently decided “I’m never investing in this again”.
Those effects are real even if they don’t immediately create a neat column in a database.
So yes — other data matters. And in this case some of the most important “data” may actually be operator behaviour that SQL only sees much later, if at all.
I guess this is another thing we see differently.
There is zero need to convince old SNOs to come back. There’s a near-infinite supply of new ones: eager to offset their costs if they hear payouts went up. And… old ones still respond to money. If the problem is capacity: it’s very literally a problem you throw money at to solve.
When Storj is dealing with 30k+ nodes… there’s no value of bringing-back an old-SNO. A new one will be fighting to take their place and their ingress as soon as the higher payout is announced.
@Roxor I think the “near-infinite supply of new SNOs” assumption is doing a lot of work here.
You once made the opposite point yourself when someone considered upgrading their connection for Storj: why commit for 1–2 years if the economics may disappear again? Peak 1 day space increase 300 GBs/node - #3 by Roxor
A new SNO after a future payout increase will ask exactly the same thing.
And just to put the “30k+ nodes” into perspective:
1,000 of those nodes are mine. :smiley:
That’s still one SNO.
So node count tells us very little about independent operators or real failure domains.
Sure, Storj can throw money at capacity later. But then the real question is:
why is keeping proven capacity now obviously more expensive than trying to buy it back later at a higher rate?
My man, you know as well as I you’re linking back to Storj’s pre-Vivant performance testing period. It’s right there in the date. Where Storj told us the firehouse of ingress was temporary. But I admire your search skills!
It is. Am I wrong? I may not have your experience: but I have seen nothing but node-count growth… for years.
What? How is keeping the price the same now… more costly than reducing it? Because reducing it saves costs now. And money can easily EaSiLy easily be added back later if needed? People are super responsive to being paid more. Like they really … like… LIKE money.
I don’t have a study to link for that.
I am aware of that. I will keep a safety buffer to compensate for that. Right now there are almost no full nodes and 66 PB of free space. Lets find some middle ground. As a starting point I would like to see about 25%-50% of the nodes kind of permanent full. Storj select is running with 75% full nodes and it still keeps up with the amount of uploads. So there is a big safety buffer and we are far away from any danger.
I don’t see an effect that wouldn’t be visible in the query results. Sure I am making assumptions about future growth and if leadership would tell me there is a 10 PB customer about to sign up I will adjust for that.
If you wish we can use self signed node tags for a little voting game. Put it into the configs of all of your nodes and all of your friends and I can tell you if you are right or not. (careful after what happened in the other thread today I could see the company use that self signed tag for something else. You are talking about trust while some of your friends are trying hard to destroy any trust. Before we put down some self signed node tags we need to get back to a healthy community. There are 2 ways to do so and I would prefer not getting forced to explore one of them. I would prefer a self regulating community that gets back to solving the chapter 11 problem at hand instead of wasting AI token on generating memes…)
:smiley: I actually remembered that post because it was one of the first posts of yours I clearly remember reading and thinking: “I have absolutely no idea what point this guy is making.”
Fair correction on the old post — I actually didn’t know that context.
Back then I was just getting into Storj, had only a small number of nodes and barely monitored anything compared with today.
But on the rest: I don’t doubt people LIKE money.
What I mean is total cost over time, not today’s payout line.
If Storj saves money now by pushing capacity out, but later has to raise payouts above today’s level to bring enough capacity back quickly, was removing it actually cheaper?
So maybe what we really don’t know is how deep that “near-infinite” pool of genuinely independent, reliable SNOs actually is at any given payout.
OK. I know. What a waste. I know. Got it.
But did you see the one where I was Brad Pitt?
If I didn’t know the group-who-shall-not-be named didn’t like me… I would think they kinda liked me.
@littleskunk I understand what you mean by the 25–50% figure, but I don’t think the percentage of permanently full nodes is a useful target by itself.
A full node is not inherently a problem, and an empty node is not inherently a problem either.
What matters is whether the network has enough reliable capacity, redundancy and room for growth at a reasonable cost.
And this is where I still see a blind spot in relying mainly on SQL.
If I move the same nodes from 4 HDDs onto 1–2 HDDs, cancel connections that only disappear next year, or simply decide not to buy another HDD again, what exactly in your SQL query tells you that happened?
The stored data and node count may look almost identical while the physical redundancy behind them gets worse.
The self-signed-tag idea is technically interesting, but I’d honestly be cautious with it right now. With all the recent discussion about identifying large operators, changing placement rules and effectively “hunting whales”, I’m not very comfortable voluntarily creating an easy way to link all of my nodes together.
And regarding this:
Please keep in mind that all of those people are also my direct competitors. I know them all through the Forum and Discord.
Despite that, and because I genuinely care about Storj, I spent time convincing several of them not to simply shut their nodes down. I explicitly encouraged them to use graceful exit instead and not put customer data at risk.
So whatever frustration exists right now, I have actively tried to prevent it from turning into damage to the network.
If there is a privacy-preserving way to measure these effects without effectively identifying individual large operators, I’d be much more open to it.
Wait that was not your current picture? That was AI generated as well? It looked real to me :smiley:
I didn’t see it :frowning: Anyway, @littleskunk, I’ll start working through the numbers now.
If I have enough motivation left and can extract enough useful data from the court filings, I’ll also try to build at least a partial business plan around them.
See you tomorrow with:
How to Survive — without reducing SNO compensation v2
@Roxor good night. Sleep on it. You were surprisingly close to enlightenment tonight. :smiley:
They would report back similar free space numbers. And in general total free space would go down. On a day with more upload activity it would be possible to measure how many nodes are sharing the same drive. Well just some average across the network.
Don’t waste too much time on it. The numbers I see on the satellite are telling me they might lie to you. My observation is that they are not open to negotiations and you have seen that today first hand. I am still hoping they will get rational at some point and I appreciate you trying to convince them but at the end of the day their actions are still loud and clear…
I remain hopeful. When most people are presented with:
  1. Some Money → Less Money
    …or…
  2. Some Money → No Money
I’ve seen them overwhelming choose Option #1. Especially those who have been receiving some money for years.
We can get through this. :100:
Meanwhile I am still sitting here and waiting for that big repair traffic… :money_mouth_face: :wink:
The premise of this entire thread is bullshit.
Declaring current SNO compensation “non-negotiable” and then spending an extraordinary number of words constructing reasons why that predetermined conclusion must be correct is pointless.
We already have the experiment running. Payouts were reduced. The network did not fall over. There is no meaningful repair to demonstrate that Storj cut below the price required to retain sufficient reliable storage. What we have instead are a very few SNOs describing how much they invested, how many disks and internet connections they chose to run, and what they may stop buying if Storj no longer preserves the economics of those choices.
That is cheap talk from suppliers trying to preserve their own revenue.
Storj needs enough reliable capacity. If it can obtain more than enough of it at a lower price, then it was overpaying. Nobody is owed a return on infrastructure they chose to speculatively overinvest in.
Let’s stop wasting time on this. Reduce payments until SNOs start actually leaving. Then increase them a bit to maintain 20% spare capacity.
@arrogantrabbit That is where we fundamentally disagree.
Reduce payments until SNOs start actually leaving. Then increase them a bit.
That basically means finding the lowest acceptable payout by waiting until operators actually start leaving.
For a storage network, I think that is far too risky.
Repair traffic is not an early warning. By the time repair increases materially, redundancy has already been lost and the network is already reacting to it.
And SNOs do not have to shut everything down overnight for the network to deteriorate. They can consolidate drives, stop replacing failed hardware, cancel additional connections or simply stop investing.
@littleskunk may be able to see parts of that statistically over time, but “over time” is exactly the problem.
One question on that though: when you said the satellite numbers are telling you they might be lying to me, I hope you did not mean that you are already seeing a meaningful increase in nodes going offline?
@Roxor is probably right that many operators will choose less money over no money. But the more important question is what happens afterwards.
Do they combine nodes to squeeze more out of their HDDs, just like Storj is squeezing our balls? As explained in step 3 earlier in this thread, that is one of the things SNOs can do instead of shutting nodes down immediately.
Do they still care as much when a node goes offline? Before the payout cut, if I noticed one of my nodes offline, I usually fixed it manually right away. Now I am much more willing to just let my scripts handle it automatically.
Do they keep investing and expanding when Storj needs more capacity? Especially if the plan actually works and demand starts growing again.
If Storj pushes too far, increasing payouts again does not instantly bring that infrastructure back. And if customer data is ever lost, the reputational damage cannot simply be reversed.
Reliability is the product. I would not find the edge of the safety margin by deliberately crossing it.
Anyway, back to the actual topic of this thread.
How to Survive - without reducing SNO compensation V2
I went through my original plan again, corrected the mistakes @littleskunk pointed out, removed estimates that were not properly supported by the public data, and rebuilt the financial and operating plan from the court filings and forum record.
The revised position is simple: reverse the September SNO cut, make SNOs whole at $1.50/$2, and solve the liquidity problem somewhere else.
The filed 12-week budget shows $930,634 of inflows against $1,309,759 of outflows, a $379,125 pre-financing gap. As of the evidence cut-off, entered interim orders support $260,000 of DIP authority. The budget assumes $388,000, while the actual draw/disbursement status is unknown.
The revised plan focuses on weekly cash control, collections, non-SNO cost reductions, paid migrations/pilots, converting the existing pipeline into actual cash, and financing or a buyer instead of using lower SNO compensation as part of the bridge.
I put the full corrected plan, calculations, error audit and sources here:
https://storage.to/RhOU7fmrG
That is the version I am standing behind now.
To make it completely finished I would obviously need access to Storj’s internal numbers, contracts and settlement data. But the court filings gave me a lot more to work with than I had before, and where the data is not public I have tried to say UNKNOWN instead of guessing.
what you speak about can be old outdated numbers, that was in the past, it mite be they dont have so big spendings any more, have you considered that?
