Hi all. There have been big drop in bandwidth used for the past few days, I’m getting nearly zero data, do you know what’s going on, and I’m not the only one:
That’s just normal variation. Same is happening with my nodes.
There are ups and downs, that’s to be expected.
Not like this. I’ve never had drop like this for over a year being SNO.
I’ve noticed a drop as well, but make sure your node is up to date, otherwise you won’t get new data.
It is, 1.16.1, so it’s the latest.
Good… I was suspecting that is something wrong with my ISP
What are you using to log traffic?
Looks like grafana. I’m using Telegraf and InfluxDB on mine.
Same here:
btw, almost 4 months old node was able to get 650GB on 8TB drive.
Look at this incredible uploads (upload link is 30mbps), look at me getting rich with 0.7$ earned in 17 days, and total ~ 1$.
@Alexey any thoughts?
Did something collapse on the Saltlake satellite?
The drastic drop has us all concerned…
not me… I’m not concerned.
My node finally vetted on the three non-test satellites just before the weekend and I was looking forward to an increase in traffic, but sadly with this apparent overall decrease, I’m seeing basically no gains to being vetted.
The traffic is between customers and nodes, the satellite is not involved in data transfer
I’m not concerned either
It’s just the way it is: some weeks are good, some others are bad. Some are awesome, some are just as quiet as a mouse. It all depends on what’s going on on customers/StorjLabs side.
We just have to be patient and take good care of our nodes while StorjLabs is doing their best for finding customers, or running more tests that make SNOs happy…
I’m in this for the long haul - some quieter days / weeks don’t matter to me as long as everything works ok in the long run.
I check my nodes once everyday for 5 minutes just to see if everything is working fine, then I move on with my life.
