Hello,
I need help!
I have all the configurations done and i am always offline.
I have a Windows server 2019.
Kind Regards
Hello,
I need help!
Kind Regards
Where i can find it?
21-04-20T12:01:41.617+0200 ERROR contact:service ping satellite failed {“Satellite ID”: “…”, “attempts”: 7, “error”: "ping satellite error: failed to dial storage node
You need to check your open ports - Open Port Check Tool - Test Port Forwarding on Your Router
Also check your public IP Address.
My port is open…
Thats not the problem.
it shows 1 and 2 and not 2 and 3
now i start a new verification
ok…
now i think i am online
Online but disqualified. You have to start vom scratch. New Identity + empty Storage folder.
You are online!
Unfortunately you are disqualified on multiple satellites, so you should delete all identity and data, then start the node again.
