Thank you for pointing out. I will delete the first photo I uploaded and re-upload it with the edited image. It’s probably saved on your computer. Thanks for your help
I hided all revisions with the IP, please check
the captive portal hijacks dns and redirects every request to their ad server. The http: server gave HTTP response to HTTPS error is because they can’t hijack the tls certificates and must serve the ads over http instead of https.
It is because of that. When I read your first message, my first thought was that it was maybe a captive portal, like on hotel wifi. Since those capture any first request before being identified and serve a page to log in with some code. Essentially turning any https request into necessarily an http request as they can’t have certs for just any domain. My guess is that this ad router works in the same way. Unless you can except specific devices from that behavior, I think you will have to leave that function off to prevent issues.
Thank you so much!
aha! After listening to it, it really could be true. Then what I modified was a realistic solution! Thanks for your reply
