I have created RPM with systemd scripts
The RPMs are built with COPR here jonny/Storj Copr
The source of the SPEC files, systemd etc: https://github.com/hegjon/storj-rpm
Still not usable for beginners, but it works great on my server.
Output from systemd:
jonny@jonny-server ~]$ systemctl status storj-storagenode@bigdisk.service
● storj-storagenode@bigdisk.service - Storj Storage Node bigdisk
     Loaded: loaded (/usr/lib/systemd/system/storj-storagenode@.service; enabled; vendor preset: disabled)
     Active: active (running) since Fri 2021-09-03 10:55:45 CEST; 33min ago
   Main PID: 2323648 (storagenode)
      Tasks: 23 (limit: 38360)
     Memory: 1.1G
        CPU: 46.816s
     CGroup: /system.slice/system-storj\x2dstoragenode.slice/storj-storagenode@bigdisk.service
             └─2323648 /usr/bin/storagenode run --config-dir /var/lib/storj-storagenode/bigdisk/storage --identity-dir ~/bigdisk/identity --console.static-dir /usr/share/storj-storagenode --metrics.app-suffix >
Sep 03 11:29:14 jonny-server.localdomain storagenode[2323648]: 2021-09-03T11:29:14.759+0200        INFO        piecestore        upload started        {"Piece ID": "OBLODFE3HX6WE6AFBEAHBX6ONYOOM5P662J6HLZRA5FI>
Sep 03 11:29:14 jonny-server.localdomain storagenode[2323648]: 2021-09-03T11:29:14.928+0200        INFO        piecestore        uploaded        {"Piece ID": "OBLODFE3HX6WE6AFBEAHBX6ONYOOM5P662J6HLZRA5FIORLBFV>
Sep 03 11:29:15 jonny-server.localdomain storagenode[2323648]: 2021-09-03T11:29:15.710+0200        INFO        piecestore        upload started        {"Piece ID": "7GEANE4OKQ45MR5S4C6XLUDXSCLXE4UU7IEKG5SFDF4G>
Sep 03 11:29:15 jonny-server.localdomain storagenode[2323648]: 2021-09-03T11:29:15.970+0200        INFO        piecestore        uploaded        {"Piece ID": "KDH2HCUVB6WYZ5QGNNZWUJHYOEM6EQUC7TFACI5Y7U55X3EQAM>
Sep 03 11:29:19 jonny-server.localdomain storagenode[2323648]: 2021-09-03T11:29:19.479+0200        INFO        piecestore        upload started        {"Piece ID": "57ICH6NTXJAA76PZRHFRTJBS2ZCWRDYSKLNGU62YCB2I>
Sep 03 11:29:19 jonny-server.localdomain storagenode[2323648]: 2021-09-03T11:29:19.718+0200        INFO        piecestore        uploaded        {"Piece ID": "57ICH6NTXJAA76PZRHFRTJBS2ZCWRDYSKLNGU62YCB2IHYILKA>
Sep 03 11:29:27 jonny-server.localdomain storagenode[2323648]: 2021-09-03T11:29:27.505+0200        INFO        piecestore        upload started        {"Piece ID": "VMTU3U7SGBVW6MICQGIC6YJHARULN2I6EAUANCSDDS3P>
Sep 03 11:29:27 jonny-server.localdomain storagenode[2323648]: 2021-09-03T11:29:27.775+0200        INFO        piecestore        uploaded        {"Piece ID": "VMTU3U7SGBVW6MICQGIC6YJHARULN2I6EAUANCSDDS3P76KQMH>
Sep 03 11:29:28 jonny-server.localdomain storagenode[2323648]: 2021-09-03T11:29:28.546+0200        INFO        piecestore        upload started        {"Piece ID": "MXJVKDWXIM6UZTM2G65NU6ESEMNAC5VOG5DCU2563IUI>
Sep 03 11:29:28 jonny-server.localdomain storagenode[2323648]: 2021-09-03T11:29:28.785+0200        INFO        piecestore        uploaded        {"Piece ID": "MXJVKDWXIM6UZTM2G65NU6ESEMNAC5VOG5DCU2563IUI7NO4DO>
Screenshot:
ksnip_20210903-113234
The RPMs are now built from source, so I have enabled Arm and PowerPC arches also
Latest release 1.44.1 is built for Fedora 34+35, RHEL 8 and OpenSUSE 15 for x86_64, arm64 and PPC. Anyone using other RPM based distros?
Updated to 1.45.3. Users can upgrade with running command dnf upgrade
I have updated the RPMS to version 1.46.3
I have updated the RPMS to latest Storj version 1.46.5
I have also updated to latest Storj version 1.46.5
The latest version is 1.50.4, the 1.46.5 version will not have any ingress, because it’s far away from the current release
See Keeping your node up to date, changes to storage node software! PLEASE READ this thread!
I released the RPM for 1.50.4 12 days ago
Are you able to use the systemd init scripts that is included? I have not yet documented them
I have updated to version 1.52.2.
