It does show where the unsigned identity is located. It also gives you the exact path. Have you tried that ?
The unsigned identity stays at the same place where it was downloaded? I have a question maybe it didn’t disappeared. the unsigned identity stays when it finish or its replaced by the signed because there’s an identity where i downloaded the unsigned identity
Here is an identity maybe its signed maybe not. I don’t know if its signed
Check this exact sentence in first image
Unsigned identity is locaed in “/root/.local/share/storj/identity/storagenode”
I was trying to make you look at
Do tell me if you find it.
