hi! … i have recived 2 txn from 0x005f7b5FAa2f8A7a647D2b2dd2C278B35429FDc6 …in the first couple of days and then nothing… ! is this normal ?
They are probably from somebody else.
We only recive STORJ for sharing hdd
Can you elaborate more ? Are you running V2 or V3 or both ?
If its V3 then you should usually receive 4 payments from 4 satellites considering you got traffic from all 4.
If its V2 then its deprecated but still being used by customers.
i thought of that to … but i hope nobody else as my adress
aaaaaahhhhhh … but no. i understand that i may had been paid for my “implementing stage”!
… sorry im a bit confused but where may i see my up time and stats ?
Is dashboard not showing your node’s stats ?
dashboard … ? the only stats i have seen are the ones on the image … posted before ! …is there any other stats ?
Please click where it says “choose your satellite” to see stats for each satellite separately
yes …thank you! i was missing that block of info! it changes to percentage when we chose just one sat !
(95/96/97/99 %) … and i was paid something like 90strj!
…but this are the actual stats and …the payments are for the month of October right ?
Payments for previous month have been completed so its November’s payout.
what? … i recived less than 100 storj’'s for the … full month? … where may i see what im doing wrong ? …
Please read up on the held amount in escrow.
ahhh … ok … there is some that stays in “held amount”. ok ! … thanks! so… ill have to search for it or … you help me :)… please…
oh… ok! thanks! … it way … way …too much to read! but … we are a team now so … i read it … ! more or less … i think it might help making something more … “visual”! like graphs or a page where i might see that “held” amount …
i understand why its needed to secure some founds … but … is that “secure” ? will i recive the storj earned or if some law changes the amount will be held at the source!?
This is explained in the article. Please read all the way to the end
The team is working on dashboard improvements so eventually, there should also be some way to better see what is your held amount at a given time.
yes … ill wait for that… ill trust the team!
but … less than 100 storj for the last 2 months… with, i think, 1tb and 400mb up/down … is (even if… at just 25%) is … kinda … not good marketing
! right!
i could/should be using my account to “gather” more “nodes” … and with this values to show of its not easy to explain!
You are getting paid for actual bandwidth provided for egress and storage, not the total capacity of your connection. Real customers up and download their files to the network, we do not guarantee that traffic from Storj will constantly saturate your available capacity. If your node is new and still in vetting, it is currently only getting 5% of the normal traffic. Once your node is vetted, it should get more data and therefore, more payouts.
hummm…i … see… so… if i make my “job” and “you” dont… you get paid plus my held amount and i dont ?! hummmm… is the “held” being reinvested ? who pays the risk of devaluing on the held amount ? sure we will be “largely” valued if the project goes as “dreamed” … plus the flood you create on the release of all the held coin …
