I’m not sure how to find the encryption passphrase.
You can specify it in two ways:
- Create an Access Grant: https://documentation.tardigrade.io/getting-started/uploading-your-first-object/create-first-access-grant
- Create an Access token and setup uplink, during the CLI wizard you will be asked for passphrase.
If you specified it, but forget, then there is no way to get it back, unless you setup a FileZilla, in the last case you can recover it:
