So i need to update my IP - and currently the node i down and i how no clue how to chance the ip?
You need to put your external IP into the run command at -e ADDRESS=“192.168…:28967” and remove and recreate the container:
and then re-run it with the new command.
If your IP is not static, you’d be better off using a DynDNS service.
Ah i see - i did a wrong ip and it is now working. Great.
