2022-08-24T20:49:37.167Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 2, "erro node rate limited by id", "errorVerbose": "ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:136\n\tstorj.io/storj/stor:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Gr
2022-08-24T20:49:37.924Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 2, "errIP address not allowed: [::]:28967", "errorVerbose": "ping satellite: check-in network: IP address not allowed: [::]:28967\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:136\n\tvice).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x
2022-08-24T20:49:38.507Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 3, "errIP address not allowed: [::]:28967", "errorVerbose": "ping satellite: check-in network: IP address not allowed: [::]:28967\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:136\n\tvice).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x
2022-08-24T20:49:38.576Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "attempts": 3, "err: node rate limited by id", "errorVerbose": "ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:136\n\tstorj.io/storj/stoe:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*G
2022-08-24T20:49:39.255Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "attempts": 3, "erroP address not allowed: [::]:28967", "errorVerbose": "ping satellite: check-in network: IP address not allowed: [::]:28967\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:136\n\tsice).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/
2022-08-24T20:49:39.378Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 3, "errIP address not allowed: [::]:28967", "errorVerbose": "ping satellite: check-in network: IP address not allowed: [::]:28967\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:136\n\tvice).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x
2022-08-24T20:49:39.727Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 3, "erro node rate limited by id", "errorVerbose": "ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:136\n\tstorj.io/storj/stor:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Gr
2022-08-24T20:49:40.797Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 3, "err: node rate limited by id", "errorVerbose": "ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:136\n\tstorj.io/storj/stoe:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*G
2022-08-24T20:49:42.633Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 4, "errIP address not allowed: [::]:28967", "errorVerbose": "ping satellite: check-in network: IP address not allowed: [::]:28967\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:136\n\tvice).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x
2022-08-24T20:49:42.766Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "attempts": 4, "errIP address not allowed: [::]:28967", "errorVerbose": "ping satellite: check-in network: IP address not allowed: [::]:28967\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:136\n\tvice).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x
2022-08-24T20:49:43.676Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "attempts": 4, "erro node rate limited by id", "errorVerbose": "ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:136\n\tstorj.io/storj/stor:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Gr
2022-08-24T20:49:43.830Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 4, "err: node rate limited by id", "errorVerbose": "ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:136\n\tstorj.io/storj/stoe:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*G
2022-08-24T20:49:44.333Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 4, "erroP address not allowed: [::]:28967", "errorVerbose": "ping satellite: check-in network: IP address not allowed: [::]:28967\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:136\n\tsice).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/
2022-08-24T20:49:45.752Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 4, "errIP address not allowed: [::]:28967", "errorVerbose": "ping satellite: check-in network: IP address not allowed: [::]:28967\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:136\n\tvice).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x
i think its somethink about the Ip but i dont really know, would be nice if someone could help me, if you need more informations just talk to me
