My email is [redacted by mods for privacy]
I hope to get my authentication code resent, since gmail sorted Storj as Promotions and auto-deleted it.
pinging someone internally, will update you when we hear back!
In the meantime, as the OP youre likely already automatically following this post inside the forum. If you also turn on notifications, you can be notified when this thread is updated.
And, again, welcome
Hello, I suggest you whitelist emails coming from hello@storj.io and adjust your spam folder to not autodelete emails immediately. If you email us at support@storj.io from the same email you posted above which I assume is the one you used to request the invite before, we can query our database to find your prior auth token and resend it to you.
I will follow your advice. I would like to thank you for the quick reply.
Thank you for the quick reply!
Glad you are set! Iām moving this to the troubleshooting category if thats ok with you and ill also mark the question as solved. (Im also redacting your email address )
Thank you for asking a question that will also benefit others in your situation!
Thats community at its best <3
Thank you for all the help, and I hope my code gets resend soon so I can get on the network.
Please check your inbox. We have sent your invite again.
I have received it. Thank you.
