OK, I’m back online after 2wks of no electricity in Oregon. Thank you father winter.
My port-forwarding looks like it’s all re-plumbed after all new IPs (UptimeRobot is green). Is there a process to 'unsuspend" a node? There’s quite a bit of space hosted that I’d like to get back on the network.
I’m seeing
Storage Node Dashboard ( Node Version: v1.22.2 )
ID xxxxx
Status ONLINE
Uptime 22m42s
Available Used Egress Ingress
Bandwidth N/A 75.73 GB 13.78 GB 61.96 GB (since Feb 1)
Disk 2.20 TB 0.80 TB
Internal 127.0.0.1:7778
External [hostname]:28967
and this in the logs…
2021-02-26T17:34:44.203Z ERROR contact:service ping satellite failed {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 11, "error": "ping satellite error: failed to dial storage node (ID: 147AbCnGCJnhWJcsFSBfhwPDmJT6fras2QHCsJPrGBfex6SDv5) at address lithos.space-to-rent.com:28967: rpc: dial tcp 73.25.200.80:28967: connect: connection refused", "errorVerbose": "ping satellite error: failed to dial storage node (ID: 147AbCnGCJnhWJcsFSBfhwPDmJT6fras2QHCsJPrGBfex6SDv5) at address lithos.space-to-rent.com:28967: rpc: dial tcp 73.25.200.80:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
Any tips?
