Identify certificate and private key not where they should be
I’m considering moving my node from one computer to another.
I was told on a separate thread I will need to transfer my identity certificate and private key to do so. I accessed the config.yaml file using Notepad++ and it says both of these files are located in: “C:\Users\Randall Stevens\AppData\Roaming\Storj\Identity\storagenode”
However. The directory “AppData” does not appear to exist. At least it does not show up in file explore.
Does anyone have any ideas how I might locate the correct directory so that I may copy the files?
Please and Thank You for any help
Randall
Appdata is by default a hidden directory. You can paste that path in file explorer and the storagenode folder will open up. You can then proceed to take a backup.
