I already have a node mounted and it works perfectly.
Now to mount another node on my second computer when confirming identity I get codes 2 and 1.
What am I doing wrong?
Thanks
Thanks
Are you running the documented process exactly like you did on the first one?
yes, the only thing that changed was port (5190) since I have another other computer with a node already created with port (28967).
Have you tried creating a new identity again?
This means it’s unsigned. What response did you get for the "identity authorize " step? Did you use a newly requested activation token?
I have used an identity created a month ago and also with an identity that I am working on. Tango to use a new identity and create it now?
You don’t have to create a new identity, but you do need to sign it.
so is a new sign up with a different email the only way to get an authorization code for a new node?
Answering my own question… no, you just need to go to Host a Node | Storj and request a new code
