Identity_darwin_arm64 not found
Hi all,
When I try to download the archive (Step 5. Create an Identity - Storj Docs, Step 5, part 1 “Download the Identity Binary”) “identity_darwin_arm64.zip”, I get the answer that such a file was not found.
Снимок экрана 2025-03-16 в 20.30.17
That specific release v1.122.9 does not have Darwin binaries for some reason. I may not have been used at all.
Pick the specific release pointed to by https://version.storj.io.
For example, https://github.com/storj/storj/releases/download/v1.123.4/identity_darwin_amd64.zip exists.
Documentation needs to be fix to account for “latest” release not being usable. @Alexey
Nope, not the documentation, the build process. I would notify the team.
Hello @YBel,
You may use the binary from the v1.123.4 release.
Thx @Alexey @arrogantrabbit . It worked.
The missing binaries have been added to v1.122.9 as well.
Yeah, but I downloaded from v1.123.4
