Hi when setting up my node using powershell all seems to go well until the final step where I am supposed to verify my identity has been created but when I use the command (sls BEGIN $env:AppData\Storj\Identity\storagenode\ca.cert).count I get a value of 1 returned instead of 2 and when I run (sls BEGIN $env:AppData\Storj\Identity\storagenode\identity.cert).count I get a 2 instead of 3 and I also can’t find the actual identity filoe which I think means its not been created right.
Any helpful suggestions. I followed the guide exactly.
Sorry just to add looking at it more closely there is this error code in the set up Error: accepts 2 arg(s), received 1
Fixed it there was suppo9sed to be a space between the command and my auth token
