Two more diagrams. One about the encryption keys. Each object is encrypted with own, specific encryption key based on the secret provided on webui/uplink:
Second is about the path segment encryption. All segments are encrypted, and same segment should have different encrypted path even if the name is the same…
Thanks. I had remembered the issue and tried to select the right setting for transparent background, but for some reason I chose the wrong option… I really need a script to export it from svg…
