After following all the steps, in the first install I got this offline status. Then I tried to repeat the set up a couple of times but didn’t improve. On the contrary now I get this error message when I try to load the dashboard via cli:
Error response from daemon: Container 38f55027f0cc433cc9a0373c38504990f7421aa223b9b7eec312c9919dc4c964 is restarting, wait until the container is running
Apparently, the set up went well but then the dashboard doesn’t work. When I try to load the dashboard in firefox doesn’t show any activity and keep saying is offline.
Show result of this
docker logs --tail 20 storagenode
It is normal that your dashboard does not start up immediately after you just started the node. Is it still not loading after at least one hour has passed?
