In terms of speed, what are your values?
Hello, everyone,
Following the changes that will likely increase traffic to the fast node.
I wanted to know if it was possible to determine whether one node would win the race against another with a simple ping like this?
Does it make sense?
ping 185.244.226.3
my result:
64 bytes from 185.244.226.3: icmp_seq=2 ttl=53 time=10.7 ms
64 bytes from 185.244.226.3: icmp_seq=3 ttl=53 time=10.7 ms
64 bytes from 185.244.226.3: icmp_seq=4 ttl=53 time=10.7 ms
64 bytes from 185.244.226.3: icmp_seq=5 ttl=53 time=10.7 ms
64 bytes from 185.244.226.3: icmp_seq=6 ttl=53 time=10.7 ms
64 bytes from 185.244.226.3: icmp_seq=7 ttl=53 time=10.7 ms
64 bytes from 185.244.226.3: icmp_seq=8 ttl=53 time=10.7 ms
64 bytes from 185.244.226.3: icmp_seq=9 ttl=53 time=10.8 ms
64 bytes from 185.244.226.3: icmp_seq=10 ttl=53 time=10.7 ms
64 bytes from 185.244.226.3: icmp_seq=11 ttl=53 time=10.7 ms
I have also made a Pingdom from Pingdom
- TCP: dialed node in 105ms
- TCP: pinged node in 51ms
- TCP: total: 157ms
- QUIC: dialed node in 104ms
- QUIC: pinged node in 52ms
- QUIC: total: 156ms
- QUIC: dialed node in 72ms
- QUIC: pinged node in 23ms
- QUIC: total: 95ms
- TCP: dialed node in 81ms
- TCP: pinged node in 22ms
- TCP: total: 103ms
What do you think? Is it significant? If so, I would be curious to know what your ping is so we can compare.
And maybe we can find some useful things together.
185.244.226.3 Sorry but that this IP number mean to represent?
$ whois 185.244.226.3
% This is the RIPE Database query service.
% The objects are in RPSL format.
% The RIPE Database is subject to Terms and Conditions.
% See https://docs.db.ripe.net/terms-conditions.html
% Note: this output has been filtered.
%       To receive output for a database update, use the "-B" flag.
% Information related to '185.244.226.0 - 185.244.226.7'
% Abuse contact for '185.244.226.0 - 185.244.226.7' is 'ops@storj.io'
inetnum:        185.244.226.0 - 185.244.226.7
netname:        STORJ-DE-FRA1
country:        DE
admin-c:        OA3075-RIPE
tech-c:         OA3075-RIPE
status:         ASSIGNED PA
mnt-by:         lir-us-storj-1-MNT
created:        2021-04-14T12:00:28Z
last-modified:  2021-04-14T12:22:53Z
source:         RIPE
role:           Operations
address:        3423 Piedmont Rd NE
address:        30305
address:        Atlanta
address:        UNITED STATES
phone:          +17348347084
nic-hdl:        OA3075-RIPE
created:        2021-02-24T08:21:42Z
last-modified:  2021-02-24T08:21:43Z
source:         RIPE # Filtered
% Information related to '185.244.226.0/24AS211541'
route:          185.244.226.0/24
origin:         AS211541
created:        2022-04-18T22:11:49Z
last-modified:  2022-04-18T22:11:49Z
source:         RIPE
% Information related to '185.244.226.0/24AS212238'
origin:         AS212238
created:        2024-11-05T10:54:10Z
last-modified:  2024-11-05T10:54:10Z
source:         RIPE
% This query was served by the RIPE Database Query Service version 1.118.1 (DEXTER)
Also see Explaining the Linksharing Service - Storj Docs
This is not a good measure because customers send their data directly to nodes, not to the satellites and then to you. Even then, distance is not a good metric; you need to incorporate peering and routing. i.e. some traffic may take non-intuitive routes to some peers.
Ping almost doesn’t matter, @Ambifacient is correct. You need mtr instead. But you would only check the route to the link sharing services, not the actual speed.
