Increase storage size & relocate storj Token/data
Is it possible to relocate storage Token & Data to a different node?
I am planning to upgrade the Token & Data to a different node with 17 TB & a different IP address. I noticed that it’s not viable to have two IP addresses in the same location since it can hurt the reputation. So I was thinking of just using one IP.
Yes. https://documentation.storj.io/resources/frequently-asked-questions#how-do-i-migrate-my-node-to-a-new-drive-or-computer
Regarding 2 IPs everything is exactly the opposite. Having more than one node behind the one IP is not so good as the only one: Add multiple drive, restart node with different parameters, and reduce Storage with out penalty
Thanks Alexey, I successfully transferred over Storj Token & Data to a new computer. Although I did receive Last Contact: Offline. I opened the port so that it is back online now. Everything good now. Thanks for the help. :wink:
I hope you transferred an identity folder instead of token. Because your token is one time usage.
If you recreated the identity, then it would be a new node.
So, make sure that you transfer exactly identity folder, not the authorization token.
Forgot to say identity folder instead of saying Token, all good :wink:
