Hi everyone,
I accidentally deleted the info.db and esed_serial files.
Is there any way to get the file recovered?
Thank you
Hi everyone,
Thank you
/path/to/info.db
to the actual one:sqlite3 /path/to/info.db
sqlite>
prompt, execute the script:CREATE TABLE versions (version int, commited_at text);
.exit
used_serial.db
:sqlite3 /path/to/used_serial.db
sqlite>
.exit
ok, now is ok!!
Thank You so Much!
