Greetings the warriors of the decentralized world! ![]()
If we are having info.db file access issue as mentioned below log outputs, is it better to delete the node permanently and create a new node from the scratch by formatting the related HDD?
If there is a way to fix this issue somehow, could you please guide me?
This issue is also related to the topic that I created a couple of days ago…
Error: Error starting master database on storagenode: database: info opening file "config/storage/info.db" failed: file is not a database
docker logs --tail 50 storagenode
storj.io/private/process.ExecWithCustomConfigAndLogger:92
main.main:478
runtime.main:250
2023-04-19 22:26:23,397 INFO exited: storagenode (exit status 1; not expected)
2023-04-19 22:26:25,417 INFO spawned: 'storagenode' with pid 57
2023-04-19T22:26:25.990Z INFO Configuration loaded {"Process": "storagenode", "Location": "/app/config/config.yaml"}
2023-04-19T22:26:25.993Z INFO Anonymized tracing enabled {"Process": "storagenode"}
2023-04-19T22:26:26.103Z INFO Operator email {"Process": "storagenode", "Address": "nazimyildiz90@gmail.com"}
2023-04-19T22:26:26.104Z INFO Operator wallet {"Process": "storagenode", "Address": "0x412c63a480cfcc6a3bd771cc33a181ba8e098067"}
storj.io/storj/storagenode/storagenodedb.(*DB).openDatabase:331
storj.io/storj/storagenode/storagenodedb.(*DB).openExistingDatabase:308
storj.io/storj/storagenode/storagenodedb.(*DB).openDatabases:283
storj.io/storj/storagenode/storagenodedb.OpenExisting:250
main.cmdRun:193
storj.io/private/process.cleanup.func1.4:377
storj.io/private/process.cleanup.func1:395
github.com/spf13/cobra.(*Command).execute:852
github.com/spf13/cobra.(*Command).ExecuteC:960
github.com/spf13/cobra.(*Command).Execute:897
main.main:478
runtime.main:250
2023-04-19 22:26:26,124 INFO exited: storagenode (exit status 1; not expected)
2023-04-19 22:26:29,145 INFO spawned: 'storagenode' with pid 67
2023-04-19T22:26:29.712Z INFO Configuration loaded {"Process": "storagenode", "Location": "/app/config/config.yaml"}
2023-04-19T22:26:29.715Z INFO Anonymized tracing enabled {"Process": "storagenode"}
2023-04-19T22:26:29.828Z INFO Operator email {"Process": "storagenode", "Address": "abcdefg90@gmail.com"}
2023-04-19T22:26:29.830Z INFO Operator wallet {"Process": "storagenode", "Address": "0xXXXXXXXXXXXXXXXXXXXXXXXXX"}
Lastly, my Suspension and Online scores were below %70 for all of the satellites.
