Hello Sirs,
Do you know, what can be the reason of zero ingress of the node? It was 79Gb/day few days ago
Logs looks fine
What is it?
Regards,
Alexander
Hello Sirs,
Logs looks fine
What is it?
Regards,
Alexander
What is the version of your node ? Are you using docker or GUI ?
GUI for this node
Update service is active here
Your node is on older version we are on 1.93.2
. You need to update your node. Older versions do NOT get ingress if they are behind certain version numbers. Here’s the announcement.
Also read
So, automatic update doesn’t work?
Thanks. After update ingres coming
oh, i remember something.
Possible there was some one time problem with automatic update around the version You have, where, i can recall i had to update manually and then it was all good again, thats may be the case. Got Windows GUI as well and everything updates well currently on several nodes, So You have to just manually instal the newest version and should be ok, just my opinion, im not a official support tho.
Sometimes it doesn’t update so manual intervention is needed. Glad its working now.
