Hi,
Could you explain me why i have got this pattern as ingress (every day).
It can’t be customers uses. It is so regular.
Hi,
Have you separated out repair ingress?
Not possible on this OS network graph but i can tell you for today, the repair ingress is only 13% of total ingress.
Ok. I just wondered if it might be repair since mine is about the same as normal ingress.
Yuck, most ingress is from saltlake. I thought we were on customer data by now
Interesting, on my node it’s egress which jumps around:
And it looks like it’s repair traffic that does this (note, this graph shows requests, not the amount of data):
While ingress does jump around a dit, it’s not repair, at least on my node:
Same for me, it repeats every 1 hour. Could be a major customer running hourly batch jobs that generate data, or backups.
I thik I found it, it was a bit lost among all the other traffic.
europe-north is one of the satellites primarily used for tests.
Hi,
So there is a lot of data test compare to users data !?
Seems like this is still the case these days, yes.
Hi,
Ok, thank you all.
