ID 1ZUC4AnyZhsRM8xpaeafSuPGGRkXTQM7TL3rhLuxLU5Gj1zb8j
Last Contact 0s ago
Available Used Egress Ingress
Bandwidth 5.0 TB 6.2 GB 6.2 GB 38.5 MB (since Sep 1)
Disk 6.2 TB 1.8 TB
& i got a mail from atikh@storj.io with a survey, saying i left network …
is there a problem?
I would start by trying the dashboard API to find out what your reputation scores are. Audit score under 0.6 means you have been paused on that satellite. It’s not exactly “leaving” the network if you were kicked off it, but perhaps it triggers the same survey.
With v0.19.0 you can now query the storage node dashboard API. By default it is running on port 14002. You have to add -p 127.0.0.1:14002:14002 to the docker command. From outside the container you should now be able to call the following API endpoints:
curl -s 127.0.0.1:14002/api/dashboard | jq .data.satellites
"12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S",
"118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW",
"121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6",
"12L9ZFwhzV…
If your node is paused I recommend emailing support@storj.io with your findings. Include your node ID and your run command in the email. As well as all relevant setup information you can think of.
Hi, thank you for reply…
i did the curl thing:
By “0.6” logic it seems i have been paused on some satelites or am i reading this wrong?
output:
> 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs
> audit:
> “totalCount”: 6591,
> “successCount”: 6564,
> “alpha”: 11.694365764989508,
> “beta”: 8.305634252500809,
> “score”: 0.5847182877381301
> uptime:
> “totalCount”: 30299,
> “successCount”: 26863,
> “alpha”: 96.95898782301005,
> “beta”: 3.041012176989852,
> “score”: 0.9695898782301015
> audit:
> “totalCount”: 3502,
> “successCount”: 3470,
> “alpha”: 19.99987465512699,
> “beta”: 0.00012534487299715156,
> “score”: 0.9999937327563501
> uptime:
> “totalCount”: 23469,
> “successCount”: 20341,
> “alpha”: 78.84315354315932,
> “beta”: 21.156846456840626,
> “score”: 0.7884315354315936
> audit:
> “totalCount”: 6452,
> “successCount”: 6432,
> “alpha”: 11.974739945223403,
> “beta”: 8.025261217171037,
> “score”: 0.5987369624627443
> uptime:
> “totalCount”: 26297,
> “successCount”: 22849,
> “alpha”: 92.46703056408137,
> “beta”: 7.532969435918551,
> “score”: 0.9246703056408145
> audit:
> “totalCount”: 7076,
> “successCount”: 7056,
> “alpha”: 11.974781142544694,
> “beta”: 8.025261278661258,
> “score”: 0.5987377871682856
> uptime:
> “totalCount”: 30155,
> “successCount”: 27286,
> “alpha”: 93.30663647134465,
> “beta”: 6.693363528655338,
> “score”: 0.9330663647134466
