Try to read the forum found similar things but nothing helped.
root@raspberrypi:/# docker ps -a
5e60fa20e074 storjlabs/storagenode:beta “/entrypoint” 7 hours ago Restarting (1) 7 seconds ago storagenode
c974f7ba7cd5 hello-world “/hello” 7 hours ago Exited (0) 7 hours ago epic_raman
15b230bdb15a storjlabs/watchtower “/watchtower storage…” 8 hours ago Up About a minute watchtower
38d9f418f8f2 hello-world “/hello” 10 hours ago Exited (0) 10 hours ago epic_driscoll
Start command:
docker run -d --restart unless-stopped -p 28967:28967
-p 127.0.0.1:14002:14002
-e WALLET=“0x************************************”
-e EMAIL=”*********@gmail.com"
-e ADDRESS=“changed.hopto.org:28967”
-e BANDWIDTH=“20TB”
-e STORAGE=”1,6TB"
–mount type=bind,source="/home/pi/.local/share/storj/identity/storagenode",destination=/app/identity
–mount type=bind,source="/mnt/storj1",destination=/app/config
root@raspberrypi:/Storjid# ls -l /home/pi/.local/share/storj/identity/storagenode
totalt 24
-rwxr-xr-x 1 root root 546 feb 29 23:36 ca.1582998872.cert
-rwxr-xr-x 1 root root 1076 feb 29 23:36 ca.cert
-rwxr-xr-x 1 root root 241 feb 29 23:36 ca.key
-rwxr-xr-x 1 root root 1088 feb 29 23:36 identity.1582998872.cert
-rwxr-xr-x 1 root root 1618 feb 29 23:36 identity.cert
-rwxr-xr-x 1 root root 241 feb 29 23:36 identity.key
root@raspberrypi:/Storjid# ls -la /mnt/storj1/
totalt 32
drwxr-xr-x 3 root root 4096 feb 29 22:57 .
drwxr-xr-x 3 root root 4096 feb 29 23:17 …
-rw------- 1 root root 7096 feb 29 22:57 config.yaml
drwx------ 2 root root 16384 feb 29 22:24 lost+found
root@raspberrypi:/Storjid# df -h
Filsystem Storlek Använt Ledigt Anv% Monterat på
/dev/root 30G 3,2G 25G 12% /
devtmpfs 459M 0 459M 0% /dev
tmpfs 464M 0 464M 0% /dev/shm
tmpfs 464M 6,3M 457M 2% /run
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 464M 0 464M 0% /sys/fs/cgroup
/dev/mmcblk0p1 43M 23M 20M 53% /boot
/dev/sdb1 1,8T 77M 1,7T 1% /mnt/storj1
tmpfs 93M 0 93M 0% /run/user/1000
overlay 30G 3,2G 25G 12% /var/lib/docker/overlay2/49afc39d591e9397155dcf1413e6feb5234e6e813b396ad813a4f8ea34e7eaf5/merged
When I write docker logs storagenode I only gets this back
root@raspberrypi:/Storjid# docker logs --tail 20 storagenode
–db.conn_max_lifetime duration Maximum Database Connection Lifetime, -1ns means the stdlib default (default -1ns)
–db.max_idle_conns int Maximum Amount of Idle Database connections, -1 means the stdlib default (default 20)
–db.max_open_conns int Maximum Amount of Open Database connections, -1 means the stdlib default (default 25)
–debug.addr string address to listen on for debug endpoints (default “127.0.0.1:0”)
–debug.trace-out string If set, a path to write a process trace SVG to
–defaults string determines which set of configuration defaults to use. can either be ‘dev’ or ‘release’ (default “release”)
–identity-dir string main directory for storagenode identity credentials (default “identity”)
–log.caller if true, log function filename and line number
–log.development if true, set logging to development mode
–log.encoding string configures log encoding. can either be ‘console’ or ‘json’ (default “console”)
–log.level Level the minimum log level to log (default info)
–log.output string can be stdout, stderr, or a filename (default “stderr”)
–log.stack if true, log stack traces
–metrics.addr string address to send telemetry to (default “collectora.storj.io:9000”)
–metrics.app string application name for telemetry identification (default “storagenode”)
–metrics.app-suffix string application suffix (default “-release”)
–metrics.instance-prefix string instance id prefix
–metrics.interval duration how frequently to send up telemetry (default 1m0s)
–monkit.hw.oomlog string path to log for oom notices (default “/var/log/kern.log”)
