I corrected some characters (-) but now i get this error:
docker: Error response from daemon: invalid mount config for type “bind”: invalid mount path: ‘</home/max/.local/share/storj/identity/>’ mount path must be absolute
You need to either authorize your identity or you aren’t pointed to the correct folder for your identity. How many files does your identity folder have?
I think you missed a storagenode folder in the path /home/dim/.local/share/storj/identity/, it should be /home/dim/.local/share/storj/identity/storagenode
Grazie Alexy,
I solved the previous problem and the node now works. Now I have prepared a second node this time on Raspberry 4, I have done the same things as the previous installation (obviously changing the software version, ie for ARM64) but when I try to start it I get an error: docker: invalid reference format.
See ‘docker run --help’
The issue is still the same - either a wrong paths, or/and curly quotes instead of straight ones (") or/and hyphens instead of double dashes (--) or/and missed back slashes at the end of the line (except the last one).
Please, post your current docker run command between two lines with three backticks ``` (three on the line before the command and three on the line after the command, this will pretty format your command here on forum). You can remove personal information.
$ sudo docker exec -it storagenode /app/dashboard.sh
Error response from daemon: Container ab2b7fd383c8685ec9545a3c8777ada28370cd040e941a0e56a5f02c1e7698da is restarting, wait until the container is running
