Hello,
I needed to setup my storjnode system from an older backup, where the multinode dashboard wasn’t installed. Beforehand I copied the files from the multinode dashboard. Unfortunately when copying the files back to there original location on the new system, and trying to start, it gives me a “permission denied” is there a way to fix this? I thought if not, it should be possible to reinstall the dashboard, and put the old db back on, so I don’t have to add every single node again? I hope you can help me out.
Thanks in advance.
