Introducing Arq backup integration with Storj DCS
It seems like the docs need updating?
Please indicate which section of Arq Integration Guide | Storj Docs needs to be updated?
I think that you need to create an S3 credentials instead creating an access grant and registering it on the GatewayMT, the last step is performed automatically in the “Create S3 credentials” wizard under the hood. So I think a link to Generate GatewayMT credentials should be enough.
