Hello may i have question so my ip address and online check ip address like what is my ip should be the same? To avoid misconfigured
What page shows is your IP address
You can get more helpful comments if you give more information on what you are trying to do.
To make the port forwarding work you need to have the same WAN IP on your router as on the link above.
Configure the Node to your WAN IP address.
Configure your border firewall to forward STORJ ports to your internal IP address.
