Can somebody explain me what IPS ar treated as one node ? Is my example in the header one node or 2 ?
Node selection will pick only one node per /24 up range. That means first 3 parts are the same.
So in that example those nodes wouldn’t share traffic.
@BrightSilence wrote
Blockquote That means first 3 parts are the same.
Can you give me example pleas which is address /24 is the same ?
https://www.calculator.net/ip-subnet-calculator.html?cclass=any&csubnet=24&ctype=ipv4&printit=0&x=99&y=2c take a look on Usable Host IP Range:
