For the last two weeks or so, about half my nodes have stayed at the exact same Used amount. The nodes will have ingress each day that far exceeds the egress, but I’ve noticed that my trashfolders are much more filled than normally. This is not exactly a problem, more a curiosity, but it makes me wonder: is all the test-data deleted? If I am just still in the process of having that removed, then no biggie.
I am a little worried that my storagearray can’t keep up, and new writes go into the trash section when I can’t win a race - I just can’t phantom that. The node in the picture below has a 4x8 TB RAID5 array and 500GB with of read-SSD cache. I’ve only got a little over 5TB dedicated to StorJ - the rest is pictures that seldom gets accessed.
If the node is online and has a good reputation (100%) - there is nothing to worry about.
Test satellites have been shutdown, so only Saltlake is remained. However, it doesn’t really matter, they are paying for used space and bandwidth anyway. And you likely received a held amount from US2 and EUN-1 already.
If there would be a need to do something special, it will be published in this thread:
Thank you! I had some issues with my ISP a few weeks back, so reputation on all the nodes are in the 70-80%. This should alleviate itself with time. I’ll be more patient and report back in week or two
