Hi there, I’m a new italian SNO and it is 15 days that my node is online!
Question… Yesterday I found a new HDD 3TB. But I don’t want to stop my actual storjNode for upgrade the storage (for adding a RAID0 with the old HDD)… I think i will start a new StorjNode with the new HDD.
What do you think about that? In the same internet connection, for example 100MB UP and 100MB DOWN, is it better to have 1 Node with 6TB, or two node with 3TB per node? The second solution, obviously, it’s 25MB up/down per node…
If you have 2 drives, then make 2 nodes, dont put them together, you will have dobled posibilitie of node fail. 2 nodes will work better, less stress to each disk.
