Is it Ffinancially worth it?
My node is now finishing its second month. The hard drive is 14TB, all the figures for suspension and audit are at 100%. Only 0.82TB is presently used and 4 satellites are virtually doing nothing. The amount earned in the second month is 1.35$.
I am really wondering if those figures are normal and if yes, is it worth it?
Thanks
This will best answer your question as only you can decide if its worth it to you. This will give you the numbers: Realistic earnings estimator
It’s is worth it if being a node is not a primary purpose for your hardware (you re using a pc that is online 24 hours a day anyway). And if you are a long-term player.
