I copied 0xF6E8…7d55 which My main account profile was generated by default by MEW, then i assign that wallet address to storagenode. therefore, my wallet address has shown in node dashboard
The problem is i have no idea is my wallet smart contract or not.
You will be paid independently of what ETH address is used. Nobody can check is it valid or not.
The only question - do you have a control on your private keys? If yes - then you would be able to move STORJ tokens out of this address with any other wallet, if the current one doesn’t work.
The MEW creates a normal ETH address, which can be used for ERC20 tokens too (include STORJ).
