I’m wondering, if there is some way to measure the daily trash. At the moment I’m getting 50gb per day, as the node grows, more files are beeing stored. As there beeing stored more files, it is more likely that data isn’t needed anymore and gets deleted. When the node reaches a specific size, where daily trash and ingress are equal, the node will stop growing, and stagnate. Is there any way to track the daily trash amount, or is there some approximate percentage of the stored data, which get deleted? In the end I would like to get an approximation, where the limit for a node size, on a regular home (single ip Adress) is.
Thank you.
