Is there a way to speed up the graceful exit process?
@Alexey , is there a way to speed up the graceful exit process? 48 hours passed and still at 10%.
thanks
Yes, you can tune some parameters of Graceful Exit, however it’s often results in failed GE if your network/hardware would be not able to keep up.
You should track the number of failed transfers in your log. Each transfer after the failure will be repeated 4 more times, then it will be considered unsuccessful. If the failure rate is greater than 10%, the node will be disqualified.
Thanks @Alexey
I,ve increased the numbers a bit in config.yaml, do I need to do anything else? I have not seen performance increase? (Restart?)
Thanks Gergo
You need to restart your node for any config changes to take effect.
