Is there any issue against using s3fs on Linux to mount StorjDCS as a drive?
Because I do so for a Duplicati backup job, although there is a Tardigrade and a S3 integration in Duplicati which seems to be very fragile in use. With s3fs finally I can max out the upload speed of my internet connection, out of the box.
These are the commands which I’m using for s3fs:
apt install s3fs
nano /etc/passwd-s3fs #There comes in your S3-Credentials seperated with ":"
chmod 0640 /etc/passwd-s3fs #Make sure only the owner can r/w and the group can read this file and others don't can do so
s3fs bucket_name /destination_directory -o url=https://gateway.storjshare.io -o passwd_file=/etc/passwd-s3fs
#And for automatic mount on reboot, put this line with the '#' in it in our /etc/fstab
s3fs#bucket_name /destination_directory fuse _netdev,allow_other,nonempty,url=https://gateway.storjshare.io 0 0 #First I had trouble with iscsi, the iscsi-daemon would not start anymore and my system won't reboot, I did start a emergency shell from CD/ISO file and purge, reinstall and reconfigure the whole open-iscsi package, then it works fine
