Is this right for making an identity?
Hi, did I run the command right, and is this what it should look like while an identity is being created?
Welcome to the forum @corviato1!
Did you try unzipping the archive and executing the .msi/.exe file ?
What is the device that you are using with your Windows ?
kinda having a hard time getting started. Downloaded all the exe files from the latest github release, but the exe files won’t run when i click it.
Downloaded the .msi file and am getting a pop up error saying "File ‘ca.cert’ not found in the selected folder.
Any help is greatly appreciated.
Yeah, using windows
wait, i think i got it. will ping if there is a problem
