I finally realized why I’m offline, my ISP changed my IP address. and my node shows the old IP. How do I correct this? thanks
Hello @wizardofwhere, you will have to stop and remove the old container and create a new one with the updated ip. It might be better for you to use a hostname instead of an ip like that this does not happen again if your isp changes your ip. You can use a service like no ip, instructions can be found here Create a Free Hostname using NoIP
Thanks for the help. I tried making changes but see this error how do I fix it?
Error response from daemon: Conflict. The container name “/storagenode” is already in use by container “03caf7e011250da07ac952a6b7446c3aa5cab96cbb2022f2f9182014fbb716f2”. You have to remove (or rename) that container to be able to reuse that name.
The error means that a container named storagenode has not been removed, you need to stop the container, remove it and then run the docker run command ie
- docker stop storagenode
- docker rm storagenode
- docker run etc etc etc
