[root@vul06 storj_earnings]# python earnings.py /mnt/storj/data/
ERROR SQLite3: Error: malformed database schema (idx_pieceinfo__expiration) - ne
ar "WHERE": syntax error
As far as I can tell, I have no issues running my node that this point.
Logs after the last restart are:
2019-07-17T14:15:49.420Z INFO Got a signal from the OS: "terminated"
2019-07-17T14:15:51.324Z INFO Configuration loaded from: /app/config/config.yaml
2019-07-17T14:15:51.338Z INFO Operator email: Scrubbed
2019-07-17T14:15:51.338Z INFO Operator wallet: 0xScrubbed
2019-07-17T14:15:51.544Z INFO running on version v0.15.2
2019-07-17T14:15:51.811Z INFO db.migration Latest Version {"version": 13}
2019-07-17T14:15:51.812Z INFO vouchers Checking vouchers
2019-07-17T14:15:51.814Z INFO Node
1Fhm5o5Ky2cmV2DwQNYqhxgei3d6ZhDrpoNtUhGhZmvLBdJTFk started
2019-07-17T14:15:51.814Z INFO Public server started on [::]:28967
2019-07-17T14:15:51.814Z INFO Private server started on 127.0.0.1:7778
2019-07-17T14:15:51.836Z INFO running on version v0.15.2
2019-07-17T14:15:52.140Z INFO piecestore:monitor Remaining Bandwidth {"bytes":
348031417457664}
2019-07-17T14:30:51.989Z INFO running on version v0.15.2
@rootdet mentioned the same issue to me. He also found that running an integrity check on the db throws the same error suggesting it’s an issue with the db integrity, not the script. But please let me know if others are having issues. The script worked fine for me on both windows and linux environments. But I only have my own node’s info.db to test on.
It is an interresting one. @Alexey had me remove my container, delete info.db, repull from github and start storagenode again. Integrity check on info.db while stopped seems to still show that error, which also appears in the earning script, and I linked it to a some INDEX creations at the bottom of the sql, but not sure why it keeps replicating to even a fresh info.db that gets created.
Will let you know if they get it sorted for me and the potential fix.
Note: If you start over with an empty info.db it will have lost the historic bandwidth usage and thus the bandwidth from prior to today will no longer be used during calculation. In addition to that, anyone reading this at a later date, please do not remove your info.db as this is likely only an option now because of the network wipe and nodes that have data need their info.db as well.
So I’m trying to run v0.15.3, I moved to a new IP at the same datacenter, when I run the script now I get this error:
root@localhost:~# python3 earnings.py /ext/store
File "earnings.py", line 127, in <module>
put_total = put_total + int(data[1])
IndexError: list index out of range
@subwolf make sure you are using the latest version of the script. It should give more descriptive errors. You should be using v5.0.0. li k is in the top post.
@rootdet@itspecific I’ve updated the script to version 5.2.0 which removes the external dependency for SQLite3 by using internal Python packages. As long as you have Python 2.5 or higher it should work now without SQLite3 installed as well.
